DSC system failure - a solution
I recently posted about random fault codes including the DSC system failure warning light, after searching through an old thread a forum member had exactly the same faults including handbrake warning light permanently on, speedo not working, low brake fluid warning and engine management light on. His problem appeared after repairing the ABS module dry joint, so thinking there might be a fault with the module I decided to remove the main connection plug and cleaned the contacts with electrical contact cleaner.
After turning the ignition on, all the warning lights went off except the engine management light and the speedo proceeded to work. After 3 heat cycles the engine management also went off, after a week no fault lights have returned.
I should note that the soldered joint problem seems to be with 4.0 litre models, mine is a 2003 4.2 XK8 Convertible which has a different ABS module.
The following 2 users liked this post by thruxitup:
scardini1 (04-19-2015),
TrevLevin04XKR (02-10-2018)
