Dtc 1649
Dtc 1649
I have a 2001 XKR silverstone edition with the supercharged 4.0l. Problem im running into is a dtc 1649. cant find a wiring diagramany where and what info i can find seems so point to a short in either power or ground to the DLC.... Any information would be apprecieated. thank you
That is an unusual code..it says there is a signal shorted on the Data Link Connector where the OBDII reader plugs in.
If it was my car, first thing I would do is clear the code. Then I would retest it with a different brand of OBDII reader (you can often get this done free at Autozone or Advance Auto Parts).
If you still get the same code, I would then look up inside the connector under the dash and check for shorted or bent pins with a bright light.
If this does not uncover the problem, post back here....you will then need to use a multimeter and perform some tests to track down the short or open.
Here is the DLC page. If you find you need the full car diagram, you should search the forum for instructions on downloading JTIS....it is too large to upload.
Also, according to forum rules, you will not be able to download this until you have 10 posts and 3 days have passed since registration.
If you are unable to open any of the links go to my page I have the circuit info you need.
trosty
26
12-18-2022 06:40 PM
KarimPA
09-27-2015 08:46 AM
shootingbrake
09-23-2015 10:54 AM
