DTC Code reads "NA"
Hi guys. 2003 XKR with rebuilt 4.2. Check engine light on. When I use my scanner come up with "NA 01/02". I know 01/02 is for two times running. What does the NA indicate? The gentleman I bought it from stated it had a bad O2 sensor but I would think that would show up (No code for that only the NA and typical P1000). Any help would be appreciated. Thanks
PaulsXK8 (09-15-2016)
You have a CEL so there must be code(s). As has been suggested, try a different code reader / scantool. It's likely the one you're using isn't compatible.
PaulsXK8 (09-16-2016)
+1 to the Elm 327 / TorquePro approach.
This will only read Powertrain (Pxxxx) codes but is as much as is needed for most faults which will trigger the MIL (CEL).
I'm 2000 miles from home at the moment and that's all I'm carrying with me reasoning that if it's anything more complicated goes wrong, I'll not be fixing it at the roadside!
foxbottom
09-11-2016 09:01 AM
Rozza
09-09-2016 02:22 AM
