dumb remote battery question
This question probably sounds dumb but my remote only works when im close to the car, i figured the battery was dead but when i opened the fob there were 2 batteries stacked on top of each other. is this right? can someone verify the size/style battery required? I drive a 97 xk8
thanks
thanks
smokphattys (01-28-2011)
The following 2 users liked this post by Martin:
MFoncerrada8 (10-05-2013),
.....following on from this point.
how long have you got from when you open the key to take the old batteries out and replace them with new ones before the key needs to be reprogrammed?
or will the key work straight away when you put it back together or do you have to reprogram it the moment the batteries are taken out?
