DVR Install (A118)
DVR Install (A118)
I'd like to install this little DVR in front of the mirror. From what I can glean from available schematics, it appears that there is a B+ line going up into the "Tint" mirror device. The vanity and map lights are enabled full time, so they are not a reasonable candidates. I expect that the rear view mirror "Tint" function would only be energized with outboard lights and/or key On.
So if the (switched) 12vdc is available up there, it would make for a much more elegant installation. Just guessing cam draws maybe 100ma @5vdc .. haven't checked it yet. A little TO-92 regulator is good for 100ma (12vdc to 5vdc). Anybody done this yet .. can anyone verify the switched 12vdc up there? TIA
I have a dash cam mounted behind my rear view mirror and I ran a wire up from the fuse panel on the driver (left) side of the dash, up the A-pillar, across the header, and down behind the mirror. The A-pillar is easy to remove, as is the header. I my opinion, this would be easier than trying to connect power and ground to the mirror wiring, and you aren't risking messing with those electronics, especially the BPM.
attaboy (12-01-2014)
Thanks for the suggestion Steve. When you say "header" I'm guessing you mean Headliner? I failed to mention .. my XK8 is a convertible .. headliner is in the top, as it were. Glad you found an elegant solution though .. also I'm guessing that your fuse-box connection was to a switched circuit, and your cam/dvr works of off 12 volts. I'll look into it .. very low current consumption .. 26ga twin-lead would work just fine .. should be easier to wrangle in there somewhere. Cheers!
I suppose if it were me and I had a 5 volt unit, I might consider wiring an actual adapter in to the fuse panel. I assume your cam came with a cigarette lighter adapter? You could hide it behind the kick panel. Just my thoughts.
philwarner
43
09-10-2023 11:30 AM
aholbro1
08-05-2021 05:02 AM
