E brake light on how to fix
So my e brake has always take a bit of force to get the light to go out. After using it today, I can't get the light to go out (although I can get the brake to release. How do I take the cover off to get at the sensor and ideas for fixing? I'm guessing it has just worn down the sensor over 20 years.
The sensor is just a microswitch. The cable that comes from the handle goes to a pivot point then from there 2 cables go to the rear emer brakes. When the handle releases the cable the cable has to relax all the way for the switch to turn off. On mine what happened was the pivot after the main cable was sticking not letting the cable relax completely. Had to take it apart and clean the old thick lube off and re-lube it and that fixed it.
Dave
Dave
TreVoRTasmin (02-29-2016)
Amelorn
04-15-2016 08:04 PM
michaelodonnell123
02-25-2016 01:15 PM
anindyam
02-22-2016 07:00 AM
