Easy fix?
Easy fix?
So there’s what appear to be 2 matching sensors on the cam covers at the front of the engine left and right...
the one just forward of the dipstick seems to be oozing a slight amount of oil. How do I cure this, is it just a case of tightening the sensor by screwing it in a bit? By hand or is it threaded needing a wrench? Do I need to remove the sensor first and if so how?
thanks
Alan
thanks
Alan
Sounds like you are referring to the VVT (Variable Valve Timing) solenoid O-ring seals. They bake in the engine bay heat and eventually get hard and inflexible, which allows them to begin to seep oil and air, sometimes throwing OBDII codes as a result. For me, they typically last two to three years before needing to be replaced. I last ordered them from rockauto.com in January 2019 and paid about $15 for the pair. The part number is AJ82856....
You simply pry them up with a very small flat-blade screwdriver, clean the area thoroughly, and seat the new ones into place very carefully so you do not deform them and cause them to leak right off the bat. I use the tip of a small wooden dowel to press the new ones firmly into place....
Removing all traces of oil and grime around the solenoid is key to getting a snug, seep-free fit....
Johnken (10-10-2020)
Alan, have a look at this advertisement and you will see it's not a regular shape.
https://thmotorsports.com/4854139-ap...saAvnBEALw_wcB
Wayne
Wayne
The following 2 users liked this post by Markel:
Johnken (10-10-2020),
Timeisrelative (10-10-2020)
