Electrical Gremlin cuts off car
I cannot find what is causing this, other than an odd "creaking" noise behind the center of the dash when driving the car. Which I cannot isolate the cause that noise, and I don't know if it's related to the intermittent electrical issue. Might be time for a trip to the dealer.
Dave,
Unable to identify the cause but I would like to make a suggestion. Purchase an extra of relays and replace one and then replace the next relay with the one you removed and continue until you worked each relay box. When you do this spray each plug with crc contact cleaner http://www.crcindustries.com/auto/co...x?PN=05101&S=N Now as you reinstall the relays be sure you make proper contact in the plug. If this is a relay problem it will move the problem to another application. This might help http://www.gusglikas.com/images/Auto.../jagxk1999.pdf I know that the car uses two different types of relays and you should get one of each to do this. As you are doing this you need to check the power and ground connections. Most people see no not see a need to check the grounds but I feel it is an important part. A bad ground can do strange things to your car and drive you nuts looking for the problem. Please let us know what you find! I hope this helps!
My suggestion to check the ignition switch is still viable. If you do replace the switch could you send it to me?
In my business grounding is a big problem that is often overlooked; it is a simple thing that can cause strange things to take place. You should check them along with the power connections and be sure they are clean and secured. My servicetechs often overlook the problem and I tell them to go back and check it again and they end up finding a bad connection that looked just fine. As for the ignition switch, I have read a few situations recently that were related to that switch on the S-Type and as I read your situation I am drawn to that switch for no real reason. We also had on the xj8 a few situations that the relays were not seated properly along with a cracked high power protection fuse being cracked and not working properly. Remove the battery cable and start from the module and work your way to the engine compartment and try not to over look the obvious. Could it be the body processor? Yes it could, but it could be a bad connection! Just be careful and use good judgment.
For the grounding go to Fig 01.1 Grounding I would assume that the ground is located near the body processor module.
Check your PM
Check your PM
The gremlin attacked my xk8 one day out of the blue....I'm driving along on a country road (no shoulder) and the car just shut down. The engine had gone dead and lights and alarms were going off. Pulled over and the car started right back up with no problems. I got it home and checked for codes and there were none. Went to the forum and read about the relays and grounds. I found a few grounds that tightened a little but on inspecting the relays I found one that was halfway out of it's socket and crooked. Pushed it back in and have driven 2500 miles since with no problems.
I had something similar except it all went dead-blank-nothing, not frozen in time. Another time it slowly faded out. After a few minutes it all came back to life. Turns out the wire to the solenoid on the starter was so tight it broke the crimp connector on the starter solenoid terminal and it was just touching it. Sometimes it would turnover sometimes it wouldn't. I extended the wire because it was so tight out of the harness, put a new terminal on it and haven't had a problem with that since.
BrentGardner
28
04-26-2024 03:08 AM
msdg137
09-16-2015 06:24 AM
Jaguar Forums Editor
Jaguar Press release
08-26-2015 05:08 PM
