Electrical problem w/gauges
replaced a leaking valve cover gasket on the passenger side and found out that if you touch the 2 cables bolted to the inner fender wall with a ratchet you create a nice spark.
Now my fuel gauge is showing way past full all the time, my temp gauge is showing almost to the red line and my voltage meter is almost pegged as soon as I start the car.
Where do I go to start tracing this problem?
Anybody have a wiring diagram for gaues on an 01 xk8?
randyb (01-22-2014)
Do what WhiteXKR suggests and with a little luck it will reset.
Link to 2001 XK8 onelines JagRepair.com - Jaguar Repair Information Resource
You can try a "hard reset", similar to just removing the cable. Only this time, touch the negative and positive cable ends together (while the battery is disconnected!) and turn the key on. This discharges any electrical current which may me stored the the various chips, etc. Then with key off again, reconnect the battery and see if your mirrors now work. You will need to reset the window stops, etc.
99xk8guy
06-05-2023 06:28 AM
