EML Ligght - Fault Code P0430
I believe that means the catalytic convertor on bank 2 is not performing up to spec, or the oxygen sensor is not working properly - the one that monitors bank 2 after the cat. Someone else will chime in. I'm not sure what to do about this except replace the cat. I would think you would get an O2 sensor code if that was bad, but maybe not. That would definitely be less trouble.
