Engie surge/ fuel tank "oil canning" 05XKR
I have an engine that is surging at approx. 1,500rpm with a very light throttle when cold (lean mixture) and a fuel tank that is noisy/"oil canning".
I have removed the fuel cap as suggested previously and this "fixes" the noisy tank.
I have checked for vacuum leaks and found none, and now removed the emission control unit from under the left front guard.
All hoses have been checked for blockages, none found. The elect switch checked for operation, OK.
The large canister checked for blockages. OK.
The small round cylinder P/n 1X43-9S446-BB is a bit if a worry, I can see through it, (through the pipe ends), it does not rattle or seem heavy, in other words its empty. (Now why would Jaguar use a useless empty cylinder?)
I had a look on Ebay and this part is described as a vacuum valve and priced at some 30UK Pd ($60 approx.). a lot of $ for an empty cyld.
Also I cannot work out how the fuel tank can pressurise/vacuum when the tank vent pipe connects to a "T" junction at the canister and the canister is vented under the guard.
Questions :- What does this plastic cylinder really do?
Is there a description of this and its use?
Why would the tank "oil can" with the above mentioned venting?
Is there a reference/diagram of the system?
Has anyone else had this problem and overcome it?
Cheers, Mike
Cheers, Mike
