Engine bay sunburn repair advice
Over the winter months I plan to do some clean up and detailing in the engine bay, painting the charge coolers, stuff like that.
In a previous life the car spent some time in the sun and the plastic bits (airbox) and also the ends of the valve covers are faded.
Any advice on how to improve the appearance of these parts?
I'm not completely against removing the valve covers to paint or powder coat them but there is not a single leak, and I'd hate to cause a problem where there was none before.
Charlie,
The car spent some time in the sun..................with the bonnet open?![Icon Confused](https://www.jaguarforums.com/forum/images/smilies/icon_confused.gif)
There's been several posts showing valve covers and airboxes refinished (red seems to be a popular choice) but the only way to do a proper job is going to be remove and thoroughly clean them prior to painting.
Received 6,307 Likes
Here's a link to vettegood's thread, I believe he painted everything in place, there are work in progress pics too.https://www.jaguarforums.com/forum/x...int-job-74358/
Now that's just pornographic. ;-)
Polished aluminum is rather what I had in mind.
My big question is what to do with the valve cover. Is there any option to clean it up, or is removal and a new gasket the best path?
Listen! I stumbled across an EXCELLENT product that really brightens up an engine bay nicely! It is called S100 Engine Brightener (Duh..) and is available at most Harley shops for around $10 a can. It has a special nozzle that "fogs" on a fine mist of the product directly onto your parts, and you don't have to wipe the excess off, unless you want to. Really brings out the color in hoses, plastics, wiring looms... anything that gets dull after time or exposure. Also works well for hard to reach areas. No odor, and lasts a long while. I use it all the time in our shop. Definitely recommended! One can will do an engine compartment, if you aren't "too" liberal with it!
KarimPA
09-03-2015 07:32 PM
