engine coolant light on
Old 03-25-2017, 12:05 PM
crg's Avatar
crg
crg is offline
Default engine coolant light on
I have a 2005 xk8 Conv. The low engine coolant light is on and the coolant is full. Is it the sensor???
Old 03-25-2017, 12:07 PM
omgimali's Avatar
What is your mixture? to much water than coolant can make the sensor not float.
Old 03-25-2017, 12:14 PM
Om28v's Avatar
The video I saw showed a guy with a cup of water and a cup of coolant. The sensor would not float in the water but did float in the coolant. After I siphoned out my mix and added pure uncut Dex Cool my light went out....been out ever since.
Old 03-25-2017, 12:18 PM
dsd's Avatar
dsd
dsd is offline
You can also jab the magnet float a few times. It's been know to get stuck.
Old 03-26-2017, 05:16 PM
Ungn's Avatar
Yes, Fish around in the coolant expansion tank with a screw driver. You may dislodge the float from the bottom or pick up the loose magnet that has fallen into the tank.
Putting a magnet on the sensor is a good test to see if its working properly/ The light will go out when a magnet is held near the sensor.
Old 03-26-2017, 05:54 PM
GGG is offline
Received 16,857 Likes on 12,186 Posts
Welcome to the forum crg,
Low coolant light on + Expansion Tank full = faulty sensor or disconnected harness connector.
Old 03-27-2017, 01:26 PM
athiker81's Avatar
Here is another thread on the same topic you might find useful
https://www.jaguarforums.com/forum/x...cement-178590/
