Engine cover screw.
If all else fails, take one of the 3 remaining fasteners to a GOOD hardware store and find a nut that the fastener will screw into with a good fit, no wiggle or looseness to it. I am guessing this fastener has "fine" threads as opposed to "coarse" (spacing between the ridge of each thread). For a good fit, you will need to match up a fine threaded fastener with a fine threaded nut. Once you have determined the correct size of the nut, it will be easy to fine the correct sized fastener. Fastener material, length and type of head are the only other things you really need to consider at this point.
http://cgi.ebay.com/ebaymotors/2004-...item33606308de
FS[Western US]: FREE- 99 XJR ECM and TCM
XJsc-guy
09-25-2015 11:09 AM
KarimPA
09-12-2015 08:15 AM
KarimPA
09-03-2015 07:32 PM
