Engine Identification and Coil Replacment Questions
Can I presume that replacing the ignition coil ( No. 8) in my 99 XK8 is about the same procedure? Take the fancy engine cover off and look down (or thereabouts?) and, should I look first for the 2 pin or 4 pin set up before I buy a replacement? It fouled out and now I can't smog the car until I fix it. So how do I figure out whether my engine (supposedly rebuilt at 47 G miles, under warranty (timing chain tensioners broke) and now at 88 G, is an AJ26/27?
Inquiring minds want to know
DocWertheimer
DocWertheimer
Received 13,255 Likes
Hi DocWertheimer,
Welcome to the Jaguar Forums! It's great to have you with us.
I have moved your post from the forum for the X300 saloon to the forum for the XK8 where you will find knowledgeable owners of similar cars.
May we assume that you have had the Diagnostic Trouble Codes scanned and the code indicated a problem with the cylinder 8 ignition coil? If you know the actual code it would be worthwile to report it here so other members will have a more complete understanding of the issues you are dealing with.
Also, since we're a friendly group, please visit the New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum and post an introduction so we can give you a proper welcome and learn something about you and your Jaguar.
Cheers,
Don
Cheers,
Don
Your '99 XK8 will have an AJ27 engine. The cover on top of the valve cover is easily removed and where the coil packs are located. I assume you got a P03xx misfire code leading you to the #8 cylinder. At 88k miles, if they weren't changed with the rework it could be a spark plug rather than a coil pack.
. . . and welcome to the forum.
Thank you, ths is great. I'll let everyone know how it goes. The car overheated for a while, I had some problems just when I bought the car that I'm slowly fixing. misfrie. then the steering columm wires. later, not now.
DocWertheimer@Gmail.com
philwarner
12-06-2021 07:13 AM
X_Type_South_Africa
12-09-2015 05:37 PM
Will P
08-27-2015 06:52 PM
