Engine replacement - What's fair?
Nearly a year ago I had to replace the engine on my XK8 due to an overheating problem. I purchased a used engine ($2,500 with updated tensioners and guides) and had it installed and it ran great for 11 months at which time "something" happened - mechanic isn't sure exactly what caused the first problem but there was coolant in the cats...to make a long story short now needed another engine replacement. Unfortunately out of warranty as this vendor only gives 6 months.
Purchased a second used engine (from same supplier - another $2,500) and had it installed....however that engine turned out to have very low compression in some cylinders. Supplier replaced it with another used engine and I had that installed and it is working great.
Question is: how much of the cost of the install and remove of the bad engine would one expect the supplier to cover? (total cost for the bad engine install/removal and fluids is about $1,500)
Just soliciting opinions on fairness. tnx
Ouch!
Were the "warranted" engines checked over/refurbished by the vendor or simply straight out of breaker vehicles but with a six month replacement in the event of failure?
When I've bought used engines or transmissions from breakers here in the UK, I was happy when they honoured the replacement on the rare failure and happy to cover the fitting/refitting costs myself. However, that's easier for me as I fit my own so it was my time and cost of materials - not so good when paying a third party to do the work.
When I've bought guaranteed refurbished units (stripped and rebuilt by the vendor), I've perhaps been lucky never to have a failure but in the event I'd expect the vendor to cover the removal/refit costs.
Depends what was in the small print on the invoice ......
labor is most often never part of the warranty on both new and used parts unless the parts provider performed the install or the installer was a dealer for the part(s) provider such as with Jasper rebuilds. the cost that you quote is on the high side of fair.
only accept used engines if they have less than 60K USA miles and your labor provider performs a compression check and pulls the valve covers and oil pan prior to installation.
before you purchase another used eBay engine, there is a California company that rebuilds these engines for not much more and has a good reputation of which i have first-hand knowledge of two good outcomes. they list on eBay. you can spend a little more and go with Jasper which will never disappoint.
MFoncerrada8 (11-28-2018)
Thank you all for the information.
I do realize I paid more for the engines than I would have on Ebay but although not refurbished the supplier (one of our sponsors) did fir them with metal tensioners and new timing guides, hence the somewhat premium cost. He also provided a small refund to help pay for part of the cost of installing and removing the bad engine. So considering the general opinion that labor is not part of the warranty I am thinking that is quite fair.
Thank you all....and good luck to me with the new (used) engine.
Yeah to get part labor on used is unique. I think you got a fair shake. The shop I use for the rare thing I cannot do insists on oem parts because he will warranty both parts and labor a minimum of one year. If the part has a greater warranty the labor follows suit .He is pricey but worth it in certain situations for me. He will only install used after his guys check out the unit and ok it for at least one year.
stevevaus
09-22-2008 08:49 PM
