Engine starts but stops immediately after. RESOLVED
#61
As for the ECM, my ECM & TCM did not have any evidence of failure internally that I could see but ASI found the problem and fixed them both. No harm in sending it to them to check it out. You have done all the things we all could think of with no success so for now it is the next best move.
#62
#66
bradstuff (01-16-2017)
#69
#70
#71
#74
Thank you Toaster!
I've put it all back together and reinstalled it for now. The board looked new. I went over it with a magnifying glass and there were no signs of leakage or burn marks. I think that if there is an ECU problem it has to be firmware/software damage. Now I didn't disassemble the ECU and look at the complete board as I figure if it comes down to it I will have to send it in for a rebuild.
I'm still unsure if that is the problem yet.
Sorry, what is with this area??????
#75
To disconnect RealGauge, disconnect the battery and unplug the larger white connector on the top of the RealGauge module (note your coolant gauge will be temporarily disabled). Disconnect the battery again when you plug it back in.
That being said, the similarity between RealGauge and UltraGauge is in name only.
Ultragauge is a generic device that communicates on the CANbus, which is the nerve center for all the electronic modules in the vehicle to communicate. If it malfunctions, it can take down the vehicle.
RealGauge is custom designed for the XK8/R and monitors the ignition, and a water temperature signal between the the speedometer and climate control system. I have never seen, and find it hard to imagine how it can cause a problem like this. RealGauge DOES NOT interact with the CANbus.
bradstuff (01-17-2017)
#76
Thank you WhiteXKR!
It is a perplexing problem. So many things to look at and think about. I've been running the car for two years as a daily driver without a single hiccup (engine wise) Before I took ownership the car had a single owner who spared no expense. It looks like a new car in many ways. Engine bay, Paint, Top, interior. To just take a dump is disappointing and since I am not a mechanic and the nearest Jaguar Dealer is 4 hours away, (I have not heard good things about them) I seek and receive excellent advice on this forum.
Thank you all for your good ideas and suggestions.
#77
#79
The number of 97 ECU failures is significant. I really think you need to contact ASI and have them test it. When I sent mine the test only cost $55, and I don't expect it to be much higher. You at least need to confirm that it's not the problem.
Automotive Scientific Inc. | Quality Rebuilt Automotive Electronics | Rogersville, TN
