engine ticking noise on tickover
1 Post
Hi I recently changed my XJS and bought a XK8 1998...The car has a ticking noise which goes when you rev it and returns once it comes back to tickover? Is this a noisy cam follower and can this be adjusted. It doesnt have a rattle from the timing chain tensioners, when you start the car from cold so i am guessing its not a noise from them.
Any help or advise appreciated..
I am attaching links to 2 videos see if this is the noise you are having Link http://www.gusglikas.com/Video/vid%2...91202-1134.3GP or Link http://www.gusglikas.com/Video/Vid%2...91218-0807.3GP
Link to my page on belt tensioner Belt Tensioner
1 Post
Hi Gus.
Prior to pulling things apart you need to get a stethoscope Sears: Online department store featuring appliances, tools, fitness equipment and more and see if you can pinpoint the noise. What is the oil viscosity you are using? The cams have an adjustment but it is not like the old days. As for inserting a photo go to your control panel and select and select avatar.
1 Post
In the 1970s i worked with a old mechanic who would use a short piece of wood to identify noises in engines..He would put his ear to the end of the shaft and the other end on various parts..Funny but he generally found the source of the noise..The oil in the car is unknow to me as i have only owned it 3 weeks and 2 weeks of that were spent at the auto transmission specialist.."The usual "... The oil is very clean and if anything looks very thick or high in Viscosity..139000 miles on the clock with mostly Jaguar main dealer services..Can the cams be adjusted using feeler guage or are they hydrolic or something?
Avatar sorted..Cheers Gus.
Thanks Gus.
innzane
09-02-2015 10:08 AM
