Engine & transmission removal??
The way we always did it at the dealer was to remove the front subframe, engine and gearbox as a unit. We had 2 rolling tables about 24" tall and lowered the car onto the tables to set the front suspension and powertrain. The engine and gearbox were separated and the tables rolled apart.
The engine was lifted and replaced. the tables rolled together and the car lowered to install.
Fastest and least damaging way I know how.
I have done this with 2 hydraulic tables but they are at the MAX weight capacity.
Hydraulic Lift Table - 500 Lb. Capacity
Without a lift you need to find alternate methods.
bob gauff
bob gauff
BrentGardner
28
04-26-2024 03:08 AM
SingBlueSilver
08-27-2015 02:20 PM
