Engine woes - the journey begins
I appreciate that - thank you
![Icon Imnotworthy](https://www.jaguarforums.com/forum/images/smilies/icon_imnotworthy.gif)
Thanks again,
Jonny
Jonny
Received 6,310 Likes
The primarys wouldn't normally effect the compression, but what you plan could be a good idea to eliminate the chance of doing a lot of work only to find something on the head has been damaged when the chain jumped due to the secondary failure.
![Icon Steer](https://www.jaguarforums.com/forum/images/smilies/icon_steer.gif)
Just to verify - which specialty tools do I need just to do the secondary's on the basis that I did jump one tooth? Thanks again.
Regards,
Jonny
Well, just in case anyone is still reading this ![Wink](https://www.jaguarforums.com/forum/images/smilies/wink.gif)
I got to work on the car Saturday and removed the damaged tensioners. Both were cracked, and missing either a top or bottom shoe. Thankfully I had Gordon on hand to answer some questions along the way. I had jumped a tooth (hopefully just one) so had to do things a little differently. Finally got all my flats in the correct spot and put it back together. Next step now is to run a compression test on the motor to make sure jumping the tooth didn't cause any damage to the valves. Not sure when I will get to do this, most likely this coming weekend.
Gus (04-02-2012)
hunter34
19
09-14-2022 11:09 PM
