engine wont start
Begin here https://www.jaguarforums.com/forum/g...d-first-30792/
and
Cylinder Wash - is this your problem? Did you run your engine for just few seconds or a minute, and now it won't start?
Detailed Procedures for Starting an Engine that ran for a moment and now won't start. (thanks Gus).
and
mike
thanks for the helpful tips my car is up and running, saved me from going to a dealer...
on another note, i have an 2001 xk8. before disconnecting the battery the windows used to go slightly dwn when i opened door and slightly up when i shut the door, now it does not who can explain how to get it to go up and down slightly when opening and closing door...this happened to me before but it went back to its memory eventually like a month later...
mike
mike
Resetting Windows
mike
mike
mike
mike
With the Door Closed, Raise the Window and continue to hold the Switch on for 3 more seconds.
Repeat for Window Down.
Repeat for Other Door.
What did you do to get it running?
mike
mike
