When I got my xk8 it had a dropped valve seat. A way to check is to pull of the plastic intake housing on the top of the engine and shine a strong light into the hole created by pulling off the intake plenum (on 8) and seeing what you can see. Another is to take a cheap camera plugged into your phone and poking it down the 8 spark plugs hole to look for damage and dents on the top of the piston on 8. Once the camera is in the bore/cylinder you may be able to get lucky and get the camera looking UP to see what you can see...
Don't run the car. A lot of unburned gas will make it into the CAT and then youll have another set of problems.
2 bolts cam loose on top row with air ratchet. then the tool became rounded and will not work. the air ratchet cannot even fit for lower bolts
this was a new snap-on socket. most other makes are too large in diameter to fit down bolt access hole
Before I yank the engine I thought I would give those bolt extractors a try
so i tried rocketsocket 13 mm and got 1 off and the rocketsocket split in two on the next bolt (:
It seems some 1/2" drive sockets fit in the hole and others do not.
I have some 1/2" drive 13 mm 6pt deep sockets arriving this week.
I may try some 1/2" drive 1/2" 6 pt deep sockets
The 3/8 drive impact sockets just have too much slop in the hole and gave me some rounding of the bolt head. Same for the 3/8 chrome sockets. And nearly all the 1/2 inch drive impact sockets are too large in OD to fit. So I had a couple machined down to within .01 inch of the hole and these then are stable and I was able to undo all but one of the bolts. The last bolt was the one the broke the 13mm rocketsocket. I used a dremel tool extender to remove the rounded shoulders and was able to use the 12 mm rocket socket to remove the last bolt.
I got the heads off. The intake seats on cyl 8 got loose. The markings on piston top are really nothing, no depth to them. I was lucky.
I think a valve job is all I need.
Amaaaazing amazing work Steve! Really. And challenging I know! Good stuff.
Hmm. Just thinking out loud, thinking if it were me... Heads for these cars are readily available. Those two indentations on the top O the cylinder, and how many times they actually hit those valves and seats MAY have done more damage than one might expect... Shockwaves thru the head.
I think I would get a new head,,, have it worked and the valves lapped out, new valve seals etc and go that way. With the $$$ you would spend on having that head rebuilt, not really knowing the true (near microscopic) extent of the damage (maybe not being able to find a mechanic who could tell ya) you could have a non knocked around head brought to near new...?
Damn dude. Ya fought the good fight!
That's sumpthin right there!
Good show
Can you post a picture of a set of valves and seats that are in place? If you don't mind. I would be interested in seeing the difference between the two.
The biggest problem i have with re using the same head is if those seats, not one but two have dropped its 99% likely the car got too hot at some point in its life. My money would be on at some point more will drop.
The reality is you can buy a good used head for way less than a shop (here) could fix those two, as theres bound to be welding and machining involved, let alone do the rest.
Something to think about if you go that route; Buy the complete head, dont try and save a bit by using your cams it can take forever to shim them to a different cam and sods law says you will need shims.
l ended up buying; 1 x good used head, 1 x top end gasket set. 1 x timing chain set (inc chains x 4, guides x 4, tensioners x 4, water pump, gaskets & 4 sprockets) 1 x full set new head bolts, 1 x new crank bolt, 1 x new belt. l belive this is the bare minimum, and im as cheap as yer quintessential European great grandparents.
Best of luck with the build, i will be right behind you, or slightly ahead depending on the shenanigan's of Canada Post
lt hasn't arrived yet, when i does i will put it on a piece of glass i have and have a poke around with a feeler gauge of a yet to be decided thickness. l dont expect problems as it comes from a reputable seller. l will PM you his details.
