Engineering the Perfect Hydraulic Pressure Reduction System
#41
No, I was not monitoring voltage, but I can.
One of the problems is the data recorder I am using is a really low end unit only capable of sampling at 120 times per second, so it cannot resolve the 22 KHz PWM signal. Also, though the scope I have can resolve it, but does not have a deep enough memory to get a meaningful picture over a long enough time period.
I think I will try to temporarily lower the PWM frquency way down, to say 30 cycles per second for test purposes. Then I can resolve the data with the equipment that I have. Maybe then I can get some more clues and see if there is a way to predict when this is going to happen and alter the drive somehow to prevent it.
#42
Not sure how the motor will react to pulses as slow as 30 cps. It will likely "feel" them. Maybe OK, but worth going slow here I think.
