Error Message: Battery Not Charging
So just went I thought I could actually enjoy my 2000 XK8 after having just purchased it 4 weeks ago, then had gearbox failure for the last 3 weeks (yes, new gearbox), and finally had it back on the road for the first time today.....
Well, we had a really bad rain storm this afternoon and I got caught on the expressway trying to make it home under extreme weather conditions, water floods and then got badly spashed by a left side passing truck! Well made it home alright, but just as I rolled in, got the "Battery Not Charging" failure message on the dash computer readout. I took it back out for about a mile, and the message would come up whenever I idled, but would temporarily go away when I was moving or accelerating. After about a mile, my steering got hard, gearbox failure popped up, airbag light on dash lit up and the Traction Control and ABS readout said it was also not working. The ASC light also came on. Obviously electrical or voltage failure.
So could this be that
A) Something shorted,
B) Something got disconnected,
C) Alternator Failure
D) Battery Failure.
It doesn't point to battery failure, but one of the other 3. Can anyone shed some light on this before I have to tow it back to my mechanic on Monday?? Thanks!!!!!
D) Battery Failure.
WillyWheels (08-11-2012)
Could something have come loose on or around the alternator?? Wires??
The alternator is located to the lower right side of the engine / engine bay. Therefore, it gets hit directly by any rising or splashing water. I can't get my head under the car to look up as the clearance is too small, or my head too big![Icon Hyper](https://www.jaguarforums.com/forum/images/smilies/icon_hyper.gif)
The fuses seem OK (checked most of them, but only faintly scanned through luggage, engine bay (x2) and driver side fuse boxes.
I think my next step is a Johnny Walker Gold Label... That will definitely help right now!![Icon Viking](https://www.jaguarforums.com/forum/images/smilies/icon_viking.gif)
![Icon Gunhead](https://www.jaguarforums.com/forum/images/smilies/icon_gunhead.gif)
![Icon Drink](https://www.jaguarforums.com/forum/images/smilies/icon_drink.gif)
Good day,
I had this happen to my Subaru... It would only charge the battery if the RPM's were up... If sitting too long, the battery would drain down to 10V and things would start to fail... Most of our electronics don't mind higher than 12V, but lower is a bad thing... I'd put a voltmeter on the battery terminals with it at idle... If you don't get over 12.8V, you need to swap out the alternator (or the internal voltage regulator)... Ahem... If you are at 12.8V or better, something else is amiss...
Good luck!!
Cheers!!!
Good luck!!
Cheers!!!
Good day,
Good luck!!
Cheers!!!
Good luck!!
Cheers!!!
Don't understand why Jag would position the alternator so low or open underneath the engine if it can be shorted by water!?
WillyWheels (08-12-2012)
BTW, if so, what is the proper method to tighten it?
Good luck!!
Cheers!!
+1 on the comment about the PS going skynet on you... water will cause any serpentine belt to slip for a little while if it gets wet.
my previous vehicle had a gatorback belt on it, which lasted longer, but still was just as finicky as any other belt i had put on it.
my serp belt was so temperamental that i would regularly have to re-tighten it from season to season.
now for your voltage issue, i believe a charging test [WITH THE ALTERNATOR OFF OF THE VEHICLE] is in order. you may have fried the voltage regulator.
also, if you didn't catch the CAPS in the aforementioned sentence... do not take your car to autozone or wherever else to have them check the alternator while it is on the car. their tests have been known to fry other electronics in vehicles. take the alternator off and have them bench test it in the back.
did i mention not to have them test the alternator while it's on the car?
Cheers!!
