EVAP Purge Valve
EVAP Purge Valve
Guys
Having a real hard time finding a EVAP purge valve for my 2000 XKR, Engine keeps running rich and my tech tells me its the valve needs replacing. I have found a Ford part F75Z9C915AA https://www.dormanproducts.com/p-73953-911-231.aspx which is a direct match to my part # LJB1515AB. Is there some reason the Ford part will not work that I should know about, otherwise its a direct fit to my Jag.
Brian
Brian
