Evaporator Core...
My indie mechanic recharged the A/C earlier this summer and all was well. A few weeks later a bit of "smoke" thereafter came out of the vents and the A/C slowly went south.
He recharged it (it only took a lb) but said the evaporator core needed replacing because he could smell the gas. He said it was a big job and would not attempt without further info.
Any other solutions besides what seems to be a big job and if it is an evaporator core any advice?
Thanks in advance.
Thanks in advance.
They don't go bad that often, I'd just replace it...if new parts price is too much, the salvage system Search Results have a bunch available between $100 - $200.
I would rather not go to a dealer...
Other than removing / refilling refrigerant, it looks more tedious than difficult.
The JTIS procedure is on my MediaFire account. You can download it with the following link:
Free Cloud Storage - MediaFire
This will give your Indie the chance to assess the removal and refit procedure.
Jag69 (08-07-2012)
I intend on making this car an heirloom...
Thanks to all who responded.
the part is cheap,its the labor thats not.8 years ago i needed one replaced in a 97 dodge intrepid,the indy wanted $800 to r&r.so i did it myself.working ten hour days at my job at the time left me with little time to spare on something i didn't want to do.it took 8 hours over two days,such is life...steve.
Gee, I wonder how so many companies make a living selling refrigerant detectors when a person can just smell a leak? Get a second opinion, normally evaporators are 'pattern failure' components - i.e. you don't read about many going bad on XK8s. That's not to say its impossible, just not common. Normally 'o'-rings, etc. are the common culprits here.
The first thing a refrigeration specialist does when a system is low on refrigerant is to sniff the whole system looking for the source of the leak.
If a shop does not have a refrigerant detector, or does not know how to use it, they are not qualified to do the job.
2000, 2002, big, core, evaporator, howtoreplacetheevaporatorcoreona1996xj6, jaguar, job, removal, replace, replacement, time, xj8, xk8, xkr
