Everything quits - reboot required
My 2000 XK8 occassionally issues a mild thump (as all systems shut down) and then the computer starts flashing all the worst warnings - transmission out, safety mode on, ABS out, etc. and goes into limp home mode which is simply idle power only. I need to pull off the road, turn everything off and then restart and everything is fine again. This is happening more frequently so I don't dare go anywhere far. I can't get any codes from an OBD scan. Suggestions? Anyone else have this problem?
first inclination, sounds like a ECU problem, throttle body, or related harness. Reminds me of the thread about the STR shutting off on the highway. Here's another link to browse.
You need a code, but from the sound of it, it sounds similar to their plight.
I would be checking the TB plugs first. I would be driving around 70mph when I would lose power and go into Fail Safe mode pull of the road turn it off and restart and back on the road for the next time. I have additional info on my page http://www.gusglikas.com/AutoRepTB.htm Give the plugs a try first. Your car fits the time for the TSB.
