Excessive Tire wear
I was getting ready to do the remote top and took off my front tires. I had a new set of Perelli's put on about 4000 miles ago. I had the alignment done at the same time, the place had a brand new state of the art machine??? Well, when I took the tires off I noticed that on the left side the inner edge was worn to the cord about 2 1/2" on the right is was worn on the inner edge but not as bad. I couldn't tell from looking and I had some vibration but because of the RP coding all the time I thought that was the vibration. Do you think the guy messed up or should I check out something underneath like bushings ? Thanks Guys
This happened to me before as well ... it even manifested itself into a slight vibration problem, btw 40-60mph. It started when I replace the rears with BFG with the front still with the Pirellis.
3-4 months ago, I changed the front with same BFG and the uneven wear issue is no more .... The bushings look ok. I still find it hard to believe that the uneven wear is attributed to different treads, but I can't explain it any other way ......
Zmann - let us know what you find out pls.
True. 2 good places turned my alignment away because they didn't have the special gear to do the XK8 properly. If I'm not mistaken they need to load the front end and then do the alignment.
There is nothing mystical about XK8 alignment. Camber is not adjustable, and as springs sag, the negative camber increases. This results in premature wear of the tire on the inside edge.
Toe in is the only easy adjustment to set. It can compensate for excessive negative camber up to a point.
Finally, caster is adjusted by removing the long pin on the upper arms, and replacing the shims in a different order; either to push the upper A-arm more forward (for less caster) relative to the lower arm; or pull it rearward.
My alignment guy works on all sorts of NASCAR and SCCA projects. He is pretty much old school and does everything using unsophisticated [read: non digital] tools. He adjusts the settings for the crown of the road and the grade on the right hand side... where we in the US ride. He also says that rotating tires is the best action you can take to prevent premature camber wear. If you cant rotate beause of different staggers... sorry.
When I bought my xkr it had 255/45 tires on both the front and back. I have learned there should be a stagger with 245/45 on the front. Is there a big problem keeping the same size tires on both axles? I know the speedometer will be off a bit (1.3%) I was thinking of keeping them the same to be able to rotate them as they have the same where pattern on the inside of the front tires.
The following 2 users liked this post by motorcarman:
test point (06-06-2011),
zmann96 (06-08-2011)
