exhaust
dodgerjames (11-15-2013)
If you do make a video it would be really appreciated. Did you do both of them at the same time or in parts?
Been thinking of fitting the over axle pipes and the end pipes from Adamesh too. £400 for both sections seems reasonable, but would want some return for my money - ie a decent amount of rumble going on.
Hi again I am thinking of using the Adamesh over axel pipes to release a bit of sound and a better gas flow.
The one thing that has held me back is:- I was told that the over axel boxes are tuned resonators to remove the drone harmonics from the car/ exhaust thus no anoying drone in the cabin. So by just replacing the over axel section of an otherwise standard system will that release a little of the V8 growl without the drone in the cabin when crusing at 75 ish.
I guess the other thing to do is wrap the over axel pipe in exhaust heat wrap ???
IanP
IanP
So just to summarize because I'm thinking of going your route.
1) You kept the center muffler?
2) You trashed the before rear axle and after rear axle resonators and installed pipe right back from center muffler to the tips using the over axle sections to get you home?
