Exhaust cam question
First of all...Happy Holidays everyone.
I had the misfortune of secondary tensioner failure in the fall ( I was waiting for the new tensioners to come in but luck being what it is lol.) A potential good note was that the car was not running at the time the failure occurred. I went to start it and it would not turnover in the slightest. Figuring that something bad had happened I opted for a tow home.
Subsequent investigation showed that the shoe had come off and bound itself in between the secondary chain and the sprocket. The chain had stretched and broke half a link but had not come apart.
So with that in mind I figure that since the motor did not turn over and that the chain had not completely broke the exhaust valves should not have been bent.
I just removed the exhaust cam and all the shims appear to be fully out, as in the valves are fully seated.
Am I wrong with my thinking? That is the question. If they are fine I will go ahead and replaced the chain and tensioners after setting the engine at its proper location with respect to DTC and go from there. If my thought process is in error please point me in the right direction.
Dale
Dale
Very fortunate!
The key is if the chain slipped a sprocket tooth or two. It is not entirely clear if the ' . . . it would not turn over in the slightest' meant that the starter failed to rotate the engine or the the engine would not start.
With the exhaust cam out it is a simple matter to check compression and/or a leak down test to verify if all valves are properly seated. With good results you are about the luckiest guy around.
Dirt bikes are not 'totaled' if a chain comes off.
There have been reports from this forum's members of repair links coming apart with the pieces found in the crankcase.
These repair link replacement chains have been used by indy shops for a long time but I would worry about it every time I drove it. I know the jump from the secondary to the Full Monty is a big one but if put to a vote the forum members would probably say that they would do the complete job.
Aus V8S
11-13-2015 11:01 AM
jagent
09-12-2015 01:40 AM
