Exterior trunk lid release button inoperative?
Old 06-29-2011, 08:12 PM
deadboy1977's Avatar
Default Exterior trunk lid release button inoperative?
anyone else have this problem?
interior release works, key works just not the exterior button
button is good
is there a fuse?
I read a bad wire may be the culprit?
Old 06-30-2011, 07:13 AM
Dennis07's Avatar
button is good
is there a fuse?
Broken wire was the culprit on my car. Right at the spot where the wiring harness is attached to the trunk hinge. Makes sense, doesn't it, seeing as how the wire has to flex at that spot every time the trunk is opened.
Had the same thing happen on an MB 560SL some years back.
Old 06-30-2011, 09:18 AM
FrogLick's Avatar
As it happens I asked my dealer service advisor about this same problem when scheduling an appointment this morning. He suggested that it might simply be that the valet button has accidently been pushed. I've not yet had a chance to check it out but hope it's that simple. If not I'll check for wire chaffing at the hinge as suggested.
Old 07-01-2011, 07:18 AM
FrogLick's Avatar
Unhappy
I didn't find any wire chaffing and the valet button doesn't seem to be the problem. Guess it's just one more thing for the dealer to check out while it's in to fix the green shower problem next week.
Old 07-01-2011, 08:14 AM
Dennis07's Avatar
This kind of wire break won't come from external chafing, which you can see. It's the repeated flexing of the wire, which can break it while things looks normal from the outside.
A continuity test will tell for sure.
Good luck.
Old 07-30-2011, 06:14 PM
rcjxkr00's Avatar
I too am having the same problem with my exterior trunk button. Have you gotten an answer from the dealer as to what caused the problem?
Old 07-30-2011, 06:33 PM
Robert Scott Neilly's Avatar
What exactly is an 'exterior trunk button'? I can open mine with the fob, the button just to the left of my steering column, or the owner's key in the keyhole in the XK8 emblem on the right side aft end of the car. Am I missing something? (Like a button?)
Old 07-30-2011, 09:03 PM
Ed M's Avatar
Smile
Across the center of the trunk: JAG[button]UAR
Old 07-31-2011, 08:53 AM
X100's Avatar
The 2000 model did not have a exterior trunk release button. The facelifted 2002 model saw the intruduction of the chrome boot plinth incorporating the release button, along with the chrome surrrounds on the revised jewell rear lights.
A lot of owners retro fitted the chrome plinth but did not wire the release button.
Old 07-31-2011, 12:42 PM
FrogLick's Avatar
Turns out my trunk release button problem was a wire bundle that also went to the tail lights which I didn't realize was out too. All fixed now.
Old 07-31-2011, 01:30 PM
ABorealis's Avatar
Close. These and other updates occurred in 2001.
Razor
08-28-2019 08:34 PM
blh-1952
09-28-2015 07:07 AM
bigblackcat3
XJ40 ( XJ81 )
09-14-2015 04:03 PM
findre
09-10-2015 05:46 PM
prettydaim
09-07-2015 05:16 PM
Quick Reply: Exterior trunk lid release button inoperative?
