Extra plug on Denso Compressor - Same model
Hey
I had to work on my compressor recently, i bought a second hand one and just replaced the clutch and soldered it onto the old unit. i had thought about replacing the whole unit but knew of how much of a pain it was going to be so well done for going down that route. So, I saw many same part numbers at much reduced costs compared to the xk8 specific one. What car is yours for? I am presuming it isnt speciifc for the xk8 otherwise the cables would match. Is there much difference between the cabling?
Received 2,434 Likes
The 97 cars monitored a lock sensor on the compressor (similar arrangement to the ABS sensors).
From 98 on this monitoring was dropped, so the sensor was no longer required. AFAIK that is the only difference between the compressors, so I imagine that you can just tape the redundant connector up out of the way.
I purchased "Denso - with Clutch A/C Compressor 471-1382" from Walmart. I used your product finder to find the correct compressor for my car. When I pulled out the old compressor I noticed the new one has an extra electrical plug coming out of the bottom that by old one did not have. My old compressor was also a Denso. Some information from my old compressor is: HFC134a, The number 447200 is on the label. There is a barcode with the following number also on the unit: F111694. Is the new unit I purchased compatible with the car. If it is, do I just ignore the extra plug?
Hey
JEPC shows Jaguar part MCA7300AD (Denso 471-1382) up to late 1997, then MCA7300AE (Denso 471-1358)
I got the Jag/Denso cross reference from the Densoproducts website but Denso proper shows the 471-1382 as applicable to both. Take a look at the website here:
Find My Part
You can see a "360° spinset" of both compressors. One has the extra lead, the other doesn't. There's also a downloadable pdf of the installation instructions if they didn't come in the box.
HTH
Find My Part
HTH
scottatl (07-12-2019)
Find My Part
HTH
Find My Part
HTH
I talked to Denso and a Jag dealer turns out Denso's lookup is wrong so every aftermarket lookup is also wrong. I suggested to Denso that they fix the issue and the rep just laughed and said maybe I have a late 1999. I told him mine was manufactured in 98. I am sure he will not try to get them to correct the info. I am sure I will not be the last to have this hassle.
Makes me wonder where the additional information comes from. Densoproducts seems to know the subtlety, as does Motorcars limited since their site also shows the 1382 as applicable to the early cars, Even the local motor factor's lookup (I was in there this lunchtime collecting some parts) quoted the 471-1358/MJA7300AE/DPC11003 for my 98.
I suspect that you would be fine with the 1382 other than needing some extra sticky tape...
manycars
16
11-30-2013 04:05 PM
Humy
12-29-2011 02:26 PM
vance580
36
03-22-2011 11:47 AM
