Failed Emissions / Mode 06 Data Question
Hey all, have a question specifically about some Mode 06 data I got on my 1999 XK8.
My car recently failed emissions because my monitors for O2, Catalyst, Evap, and Continuous Component were not ready. I have driven 300+ miles since the test and still the tests are not ready.
I do not have a check engine light, but after looking through Mode 06 data, my software (OBD Auto Doctor) says I did have a "Manufacturer Specified Component $11 / $07-Minimum Sensor Voltage for test cycle (calculated)" Failed result on a value of 0.200V.
Hoping someone can help me decipher that since I cant seem to find an answer via google. Is it the reason those tests will not complete?
Thanks for the thoughts.
I had the car shipped across the U.S. And they disconnected the battery during the transport which reset the monitors obviously.
Fuel trims look ok I think...long terms are steadier around 6% and short terms are more variable but says they average around 3% . Does that sound about normal?
I think it is worth a try to replace the Purge Valve, a fairly easy job, and not that expensive even if you pay an independent shop to do it.
The newer version also adds a filter (simply plumb a small fuel filter to it). Of course every case may be different, that said I had the same problem with my 2000 XK8 and it turned out to be a bad purge valve which of course kept the EVAP from running, but it also kept other monitors from completing too. The bad purge valve did not set a DTC.
Tahoe Dave
01-20-2016 09:31 AM
