Failsafe Engine Mode
Guest
Posts: n/a
My 1998 XKR has just started displaying the Failsafe Engine Mode warning. What does this warning indicate as it seems to come on with the ignition prior to starting the engine and stays on when started. The car seems to be running as well as normal. I am not sure what I was doing when it first came on but I seem to remember reseting the trip counter, is it possible to reset the computer and see if it comes on again or any ideas on what is the most likely cause of the problem. I recently had problems with Suspension Fault displaying intermittently which turned out to be a faulty sensor after many visits to the dealer trying to track the problem down at great expense.
Guest
Posts: n/a
RE: Failsafe Engine Mode
Thanks everyone for your advice. Next time I used the car the warning had gone away and lasted for a few days only to come back on for one trip yesterday and then fine again today. I am in Australia so do not have access to an Auto Zone so will have to take it to the dealer to get the codes read.
I am getting this failsafe message before and it will flash while the car is running. It ideal higher then usual, will not accelerate untill peddle is at the floor. And then it will only goes a little faster I have tryed to clear the code with my OBD2 code reader but the message will come back. I am now getting the message "Elec. throttle control position error." What am I doing to get this and is it possible to CLEAR the falesafe engine mode ?
Buy some electrical contact cleaner at your auto store. Carefully remove the throttle position sensor connector and spray the contact cleaner into the cable end of the connector, not the throttle position sensor end. Sometimes contact resistance gets high enough to cause trouble code P0121 and this will put the car into failsafe mode.
I had the same issue. I brought my 98 XK8 to the dealer. The service manager told me it was likely the brake switch (prior to testing). He was correct. He stated this is not an uncommon problem with the XK's. I would suggest bringing this to you dealer's attention prior to any expensive "attempts" to repair. Good luck....
I have the same message popping up on my display. It normally shows up right as the engine reaches it's normal operating temp (half-way on the temp gauge). That's when the cruise control stops functioning. Other than that, I have no loss of power, or any other strange behavior.... Haven't checked the brake switch yet, but I think if that was the problem, the message would show up right away, and not wait for the engine to worm up... Right? May take it to AutoZone to have the codes read this weekend.
PS
The message just started like last week. It's been less than 5 days that I'm driving it this way. Funny thing thoug, last night I was coming back home and as soon as I got on the Hwy, I put the car in cruise, right before it reached the "operating temp" and the message never came on, and cruise worked all the way home... Needle in a hay-stack...
PS
PS
PS
I think you may have a completely different problem. Are you saying that you ARE getting the failsafe engine mode warning on the dash but the car is NOT going into "limp" mode where you have almost no power? Give us a little more info about what exactly is happening, what the display says, and what year car you have.
Correct, no limp mode... Just the "failsafe" message, which shuts the cruise control down. Other than that, no rough idle, no limp mode, no other messages, well except for the "stability control disabled" message I've been driving on for the last 2 yrs, which could be anything from the ABS control unit to cables to $300 ABS sensors at the wheels...
Received 1,700 Likes
now I normally start the car in neutral, and even though there is nothing wrong with my charging system or battery, I keep a battery tender attached to the car whenever it sits overnight or longer.
Guess what ? No more failsafe or restricted performance messages. Maybe I’m just practicing voodoo, but the cost is zero and the failsafe gremlins are gone.
Z.
The following 3 users liked this post by motorcarman:
