Failsafe Engine Mode question
When I start up my 2000 XKR, about a third of the time the “Failsafe Engine Mode” message will appear on my dash for literally less than a second immediately after ignition, but then disappears. It’s never lasted more than 1 second. Is this normal or should I get it checked out? There’s no engine lights on.
Any idea if I would need a scanner that reads jaguar-specific codes for this type of problem, or would a generic scanner probably work?
People seem to reccomend the Innova brand. Seems that it will show pending codes, according to one reply about the product.
Check out this sticky on OBDII readers -
OBDII Code Scanners ** Member Approved ** - Jaguar Forums - Jaguar Enthusiasts Forum
Snack, just remember: while the reader will display the correct alpha numeric fault code, IME its rare that the English description shown on the reader is correct.
Iow, copy the code down, look it up. We have references on here. Or just Google 2003 jaguar xk8 code (number) . . .
Might save you time and headaches.
John
John
