Failsafe mode & check rear lights
We are having a bit of a problem with our 2002 XKR. For the first 20 minutes or so everything is fine. Cruise control works fine, no error messages. Eventually the cruise control won't work, but the cruise control light is still illuminated. That goes on for 10 minutes. Then the cruise control light goes off and "check rear lights" and "failsafe mode" is displayed. Cruise control doesn't work at all. However, the car still runs fine. If you then pull over, shut off the car then restart it and continue on the cruise control won't immediately work, but after about 5 minutes it starts to work. After that the whole process repeats over.
Using a generic OBDII code reader is pulls code P1642.
I'm leaning toward the brake pedal considering cruise gets turned off like someone tapped the break (but hasn't) and its also displaying that rear light message. Any ideas?
Here is the readout of the P1642 code
Default Action:
P1642 CAN (controller area network) circuit malfunction Ignition ON > 5 seconds
When fault is detected, ECM (electronic control module):– Limits throttle to approximately 30%
– Inhibits cruise control (All CAN data unavailable)
Possible Causes:
CAN short circuit fault
Control module failure – check for additional flagged DTC(s) (diagnostic trouble code(s)) to locate control module source
Default Action:
Possible Causes:
I see the code you are getting but you said that you are not getting a limited throttle.
There are a few threads and I think Rev Sam did a video on the replacement.
The brake switch is sort of spendy.
A handy guy could easily remove the brake switch assembly and just replace the two micro switches and save a lot of money. They could not be easier to get to and I believe they are rather common. There is a thread here on the Forum in that regard.
BrentGardner
28
04-26-2024 03:08 AM
