fans runs continously
jam1white (09-29-2011)
It would help if you would post your model and model year in your signature or avatar.
The fans are controlled by the temp sensor in the upper coolant plastic pipe on an XK8 reporting to the ECM that fans are requested. The ECM operates two relays to turn on one or both of the fans.
First GUESS is that you have a temp sensor failure, cheap solution but just remove the wiring connector and see what happens.
Second GUESS is that you have a sticking relay.
JagYi,
Was looking for XKR cooling stuff tonight, came across these links, thought I would share.
Very detailed coolant and thermostat replacement instructions:
http://matt.zenfolio.com/xk-coolant-...tat---v1-1.pdf
Discussion of plastic vs metal thermostat housing
https://www.jaguarforums.com/forum/x...housing-13871/
Instructions on how to make the hood go 90 degrees up without removing it, and more t-stat housing discussion:
https://www.jaguarforums.com/forum/x...housing-13044/
Frequently asked DIY / maintenance questions:
https://www.jaguarforums.com/forum/x...ts-data-29800/
And while in that area, can easily do the main drive and supercharger belts (esp since if they get coolant on them, they will be poisoned and start squeaking) :
https://www.jaguarforums.com/forum/x...acement-42373/
https://www.jaguarforums.com/forum/x...er-belt-41502/
I did my waterpump from instructions in the JTIS. Can't find it just now for the XKR, but it was avail for XJR in the forum. Haven't made JTIS work for me on Vista64 yet, that is my next Jag project.![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
hth,
hth,
To be fair - test point is right, analysis is required. I just threw parts at my car because I was refreshing the cooling system.
The problem is that I just got lucky. In my professional life as a database performance guy, I often warn people against just guessing like I did. It often results in lost money, wasted manpower, and a nasty blamestorm if it doesn't work out.
But, I am unsure exactly how I would have assessed it. I guess the first thing I would have done would have been to independently determine coolant temperature. I suppose another test would have been to boil the thermostat to see if it opened and stayed that way.
Unsure how to test waterpump flow.
Have a good day, all.
jam1white (10-17-2011)
trosty
26
12-18-2022 06:40 PM
kevo
09-08-2015 09:45 AM
