Fault code 0455 2001 XK8
Is it an OEM gas cap? If not, definitely replace. Check the sealing surface where the cap meets the filler neck. It must be a uniform fit or it will leak vapors. I'm pretty sure there's a TSB for an 01 and older XK. I may be wrong though. I'm just going by memory. Check for TSB's here in the X100 section to verify.
noterman (03-16-2016)
hjt1948
03-05-2016 05:20 PM
