Fault code P0197
I recently changed the valve cover gaskets since they were leaking oil. I have noticed an intermittent oil smell when the car is not moving since the new gaskets were installed, but there is no oil on the engine or the floor. After a week, the check engine light came on and I have a P0197 code, which indicates "engine oil temperature sensor low". The oil level on the dipstick is down a little. Any ideas?
Attached is a list of codes for your car so you can see the default action and causes. You may want to check all plugs you were working near also do a hard reset and see if it clears.
Link http://jagrepair.com/images/AutoRepa..._2001_OBD2.pdf
walkman1 (04-23-2016)
Nee_the_Bogeyman
04-03-2016 10:41 PM
