Faulty Purge valve
Old 02-26-2011, 01:24 PM
djpxk8's Avatar
Default Faulty Purge valve
If the smell is caused by a faulty cannister purge valve as some of the threads suggest. When I take the wheel cover off how will I know if the purve valve is faulty? Will I be able to smell the gas? do I need the engine running to check for leak? how can you test this valve?
Do I just replace it and hope for the best???
I have already replaced the cannister close valve under rear axle.
boiler
US Southwest
10-17-2015 09:35 PM
Johncy2000
10-02-2015 01:05 AM
jjmiah217
09-28-2015 09:09 AM
Camnelson324
09-27-2015 08:48 AM
Quick Reply: Faulty Purge valve
