Fight to take off the wheels... Is it only me?
Hey Guys,
So I did the brakes on my 06 XK8 yesterday. And the most difficult part of the job was getting the wheels off the car. My wheels are just stuck. I had a rubber mallet and finally had to use a pry bar between the wheel and the rotor to get the wheels off the car.
I am realizing that if I get a flat, I can't even change the tire on the road. This is the 2nd or 3rd time I have had to take the wheels off and its always a struggle.
Am I just special, or do others have this problem ?
For those curious I installed the EBC Red pads. Hoping for less dust on the chrome wheels. And while the hood was up saw a collapsed radiator hose. So this coming week I am going to change the radiator hoses. Looks like it will be lots of fun, all those nooks and crannies and my hands are not tiny.
Dave B
Dave B
Received 10,871 Likes
Everyone is right about the sticking wheels.
If you don't want to have to keep a 3 lb. sledge hammer and a block of wood in your trunk, use the copper grease.
The other option is to rotate your tires every time you do an oil change, and they won't stay on long enough to get stuck--assuming all 4 tires are the same size.
Some guys, when faced with a stuck wheel, leave the lugs nuts a couple turns loose and then s l o w l y drive in a figure-eight. The wheels will break free but stay on the car :-)
I use ordinary wheel bearing grease on the hub-to-wheel mating areas to prevent corrosion.
You must have been around awhile.
Received 9,007 Likes
I used a small dab of anti-seize lube on the lug nuts and small smear on the hub. always am careful not to get any lube on the disk or pads.
Too much lube on the lugnuts can have change your torque settings slightly if you use a torque wrench to put on the lugnuts, I am told.
Maybe our tech experts will comment on that issue.
Bradley Chambers
39
02-11-2016 10:55 AM
