Figured out that 18 pin phone connector for Bluetooth install
An extra bit I found out, by accident was that this connector has an extra "accessory on" wire. Its on the bottom row under the 12v switched and the mute wire. This "accessory on" is only active when the engine is running, and turns off with engine. I found the old Nexxia SOT-126 uses this wire, instead of the 12 switched. So whatever is using that wire only works with engine on. Just in case anyone wants to adjust theirs.
Julian Black (11-27-2016)
![](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/139461d1480322997-figured-out-18-pin-phone-connector-bluetooth-install-telephone.jpg)
Worth adding again and putting a link to this thread in the FAQ 'HOW TO' thread so we have all the information in one place.
https://www.jaguarforums.com/forum/x...ts-data-29800/
It's under Factory Phone.
![](https://cimg1.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1124/20180415_183834_4d1e78a4306ea3828619bd49e3f96010e774f35e.jpg)
Anybody able to help decipher these? I'm trying to power an aftermarket Bluetooth system with 12V ignition switched power and a clean ground, but can't seem to match up the pins on these connectors to any charts I can find.
Thank you for any help!
![](https://cimg8.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1124/20180415_183834_f89ddae853e3381fec8ed867cb4d7a4f66a42ec0.jpg)
![](https://cimg0.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1124/20180415_183821_c2310fae6d8542b3ca805c7742abbdb29e79d1a3.jpg)
If your car doesn't have the OEM phone kit, the yellow connector won't be connected to anything. If it does have the phone kit, it will be plugged in to another flying connector (not plugged into a module). The wire colours you want are as described at the start of this thread.
