First test of brushed titanium wrapped console fascia
#42
#43
The good thing is that the wood is still under the wrap and if u tire of it it simply peels off!
![First test of brushed titanium wrapped console fascia-image.jpg](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/58487d1480969931t-first-test-brushed-titanium-wrapped-console-fascia-image.jpg)
#44
I don't agree! Its a very sport look and your XKR is a sports car!! Brushed metal looks great in any car. I didn't think I would like it and actually planned to tear it out but now I cant stand the thought of the wood any more!!! It feels SOOO neww!!
#46
I ordered from ebay. And I used a flexible wallpaper border blade. Actually used a soft cloth as I heated with hair dryer to stretch and press down. Cleaning surface is most important. And back of piece. And ONLY buy 3m brand.
#50
The corners are a bit harder, I had to heat it and really pull tight as I pressed it down. I realized to keep pressing with the soft cloth until it cooled and it stayed better. If you can fold it to the back and get it to stick, it stays much better.
Cleaning front and back is essential. And there's a small felt strip on the edges of the panels that has to be totally removed. I used goo gone to clean off tape residue from felt, then cleaned with 409 several times to really clean. Can also use rubbing alcohol.
It's easy once you get the hang of it and the corners and edges really hide well if you get a small crease. I'm going to add a small felt strip back when I'm satisfied with my finish.
Hey, it's fairly cheap and reversible.
Windycityx (10-27-2013)
#51
Thanks, great tips! I have been debating on getting it stained piano black, I just know as far as resale, 95% won't like it. And after seeing your car and already wanting to go black headliner, I think the 3M Di-noc carbon fiber may be the right one to try. And the of course, the fact it can be easily removed it's the way to go.
BTW how much did you order?
It takes practice. I ordered more than I needed and played with it. Once I had it smooth on the surface, I used a hair dryer and heated the gage openings and pressed it in around the edges. Then I cut a small hole in the middle and pressed it to the finished edge and cut slite so I could fold it around the back.
#52
If you do carbon, PLEASE try to match the pattern!! It will be harder but try to line up the pattern at the bottom of the fascia best you can. Otherwise, it will look wonkie!!
Maybe try the black brushed metallic if you really want a black. I personally think the carbon wraps look kinda cheap. Just my 2cents. I'm certainly not one to judge!!
#53
Yes I saw a picture of someone who did that on this forum not matching the pattern up. I like the black brushed metallic for sure, I may go with that, thanks!
I think I ordered 24x48".
#54
I have used 1080 on things, and not tried the Di-NOC personally, but, the Di-NOC is generally intended for flat surfaces and is a thicker film, so not as easy to bend. The 3M 1080 is a little thinner and easier to work around curves.
#55
Phil
Looks excellent with the black interior and if my cars interior were black I would shamelesly copy you.
But I bought my car for the classic Jag look, I'ld wanted since a boy, with pale interior and walnut. To me it just feels more "jaguarish"
if that makes sense at all..
![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
#56
![First test of brushed titanium wrapped console fascia-image.jpg](https://www.jaguarforums.com/forum/attachments/xk8-xkr-x100-17/98293d1480974058t-first-test-brushed-titanium-wrapped-console-fascia-image.jpg)
I replaced my XF ugly wood with carbon fiber and brushed black steel so I want wood back in the XK8!
280zx-turbo
09-10-2015 06:29 AM
