first time XKR owner question
Hi all - I just purchased a sweet 2000 Jag XKR from an owner in Virginia. The car is in pristine shape, but we're learning fast about error codes, and in fact bought our first code reader on Sunday. One of the basic issues appears to be the coils or the injectors, and I'm trying to find out if an additive, like Lucas complete engine treatment, might help in keepin the injectors and flow paths cleared out. Thanks in advance for any advice you can offer.
SharonXKR (09-05-2018)
Best is probably not to start with the expectation that some product is going to solve true problems. You seem to suggest there are error codes. Those are your friend, mostly because they are specific and easy to search by. Feel free to post them here for more specific help. And welcome to the group.
For fuel, this area has ethanol added (at least in the winter months), so water contamination should not be a problem. If you use premium gas, the additives put in by the fuel manufacturers should normally render these store additives unnecessary. Has the car been sitting a long time before you bought it?
Best of luck, keep us posted.
Received 1,701 Likes
FWIW, Techron is the only fuel additive which I've personally seen have ANY effect on a known injector problem. But you have to get the stronger "Complete Fuel System Cleaner" not the "Injector Cleaner" .
And use the large 20 oz bottle, or two of the smaller bottles per tankful of gas.
You are paying for the convenience of not having to take the injectors out to clean or replace them, so expect to have to repeat use of the Techron 2 or 3 times in successive tanks of gas.
Z
Z
The following 2 users liked this post by zray:
CorStevens (09-08-2018),
What are the codes?
The only injector issue I've ever had ended up being electrical inside one injector (the one at the front left of the engine above vertically of the PS pump). Luckily, it was what looked like only one of 2 that could be replaced with the supercharger installed. Someone here posted how to test injectors, an excerpt from the Jaguar software, and it failed the test indicating injector replacement. A bottle of anything would do nothing there, anything short of injector removal and replacement would have done nothing.
If you want your fuel system cleaned then get it Terracleaned. Its not an additive its a process. In the UK we have to have our cars emissions tested each year and since my engine was Terracleaned its been spot on. I do not mean good I mean excellent.
Will see if I can find a video for you.
Here you go
I do not work for them etc. Its one of the very very few treatments I would recommend.
Here you go
The following 3 users liked this post by frankc:
Would love to try that. Hope it becomes available everywhere.
there are numerous "home brew" decarbonizing methods that one can do that use Seafoam or even plain water***. The liquid of choice is dripped or injected. SLOWLY into the carburetor or intake. What comes out of the exhaust pipe will resemble a fogging machine. On older cars I would take them out of town to a deserted spot, so I wouldn't be fogging up the neighborhood.
But the results are exactly what your video shows.
Z
*** anyone that's seen a head gasket blown into a combustion chamber knows how well a little water (or antifreeze) can clean the top of the piston, cylinder head, and exhaust valve. It turns to steam, and you have an unwanted steam cleaner st work.
Error codes
Thanks to everyone for the responses! Here are some more details on what I saw. I bought the car last Monday and drove it home on highways from Manassas VA to Bowie MD (about 50 miles). It ran great. It took me a few days to get tags, etc in place, so next time I drove it was Saturday. Was a ~10 mile drive on back roads (no high RPM), and after driving through a rain downpour, i noticed it running rough and then saw the check engine light and "Restricted Performance" warning on the dash. We took it to AutoZone to get codes read the next day and read P0302 Cylinder 2 misfire; P1316 misfire rate; P0352 Ignition coil B. We bought a code reader and confirmed the readings, then reset the codes. It was running great and the codes did not come back. I have a new coil pack on order (the prior owner just replaced plugs and coil #8). Tuesday I drove it to work and Check Engine light came on again, but this time the code read P0174 Fuel system too lean. I just reset that to see if it comes back.
The previous owner drove it fairly regularly, and filled the tank just before I brought it home. Maybe some faulty fuel? although he said he always uses Premium from reputable vendors. Today I put in about 1/2 tank of Shell premium. It feels and sounds great (awesome), but I have not driven it again since I just reset the codes tonight.
I appreciate that the additive might be a temporary fix but at this point, i just want to get it through MD state inspection. I have the Lucas brand, which the guys at the shop said is the same thing as the Seafoam. I am also wondering if I should do nothing until I drive it a few more times and see if the codes come back now that I have put new fuel in.
Thanks again for all of the help. I never thought I would actually own a Jaguar!
All, I posted more details in a reply below, including codes. Thanks again for all of the help.
In short, you need to figure out where the air leaks are (they are cumulative, and each one contributes to the code). Start with cleaning the air flow meter (by the air box, use a dedicated spray from the parts store), check top and bottom of the big intake pipe (and all resonators) for cracks. Also check ALL connections going to and from the heads and the throttle body. On my later car, these are all Norma connectors that pinch/pull easily and can be fixed with new o-rings (Harbor Freight has great kits of o-rings for cheap). Check the dip stick seal. I am less familiar with this, but the supercharger has seals too that are known to leak if they are of the original design. A later part is available.
Also, now would be a good time to make sure you have a code reader that can read Fuel Trims. Do a search for ELM327 on eBay or Amazon for a CHEAP wireless reader you can pair up with a mobile phone app. This small device will pay for itself MANY times over. The idea is to observe/confirm the idle fuel trim number going down as you fix each air leak.
PS: Also check for oil leaks around the head. Oil leaking out means air going in...
SharonXKR (09-06-2018)
I am surprised nobody has advised Sharon to first replace the battery. Trust no codes until you trust the battery.
A good AGM battery is less than $200. The Advance Auto in Bowie has it in stock. Order it online for store pickup and you can get 20% off.
BTW - good color choice. One of the few colors that never gets old.
Update
Yesterday, after i reset the warnings, i drove around 50 miles, some highway, some back roads, traffic lights, etc. No lights or warnings came on. So, i will continue to monitor. Thank you again for all of the advice.
I am curious if anyone has experienced warnings flashing up after going through the car wash. I took it through the other day (brushless, no touch). when the air dryer came on, all sorts of error codes came flashing up on the display. but, i just shut the car off and turned it back on and everything reset. I guess that is a possible clue related to the air sensor discussions above. Will keep an eye on all of this.
Do NOT run an XK8/XKR through an automated car wash - EVER. Too many extremely sensitive electronics in the engine bay and the slightest bit of water in there can cause all levels of havoc, as you have already experienced. Take the time and effort to hand-wash the car and be stingy with the garden hose around the windshield and hood areas. Your electronics will be most grateful....
SharonXKR (09-07-2018)
Wondering if it has to do with how old the car is and/or how the environment has affected sealing rubber. Here in humid Florida rubber seals seem to hold up well.
I do agree that hand washing is preferred.
You have been fortunate if you have washed your engine bay without compromising your electronics. I never washed my now-sold S-Type's engine bay during 9.5 years of ownership, and I have never washed my wife's XK8's engine bay either. I clean them periodically with a bit of silicone spray, some old cotton towels, and plenty of elbow grease....
Jim
SharonXKR (09-19-2018)
