fitted new abs pump+module but still not working "97 XK8
Chris I am moving this post to the "General Tech Help" sub forum until we know your MY and model.
Welcome to the forum. You might want to go to the "New Member Area" and properly introduce yourself per forum protocol.
Also please use "UserCP" tab upper left and add your vehicle details so you can help us help you.
chris8spurs (04-08-2013)
Received 6,330 Likes
There are many part number and software variants.
If part number does match, the unit may still need to be reprogrammed to your vehicle by a dealer of an independent Jaguar specialist unless the software versions (on a label under the carpet in your boot) were precisely matched.
Also, are you sure the old one was bad? There are many causes for the traction failure, any many do not involve the pump or electronics. Research here on the forum and on www.jagrepair.com.
FS[SouthEast]: GenRad GDS-510 scan tool
johnnie ryall
10-19-2015 09:44 PM
