Fix for sensor behind mirror, that turns on headlights?
I suppose one workaround for the problem is to partly cover the sensor in the mirror with black tape.
There is likely a problem with the circuit board or sensor inside the mirror. It is possible to crack open the mirror and reglue it, but it is a tad delicate operation. The problem sounds like it could be flux contamination on the circuit board and a good clean in isopropyl alcohol might just cure it.
mrplow58 (07-09-2015)
KarimPA
09-03-2015 07:32 PM
