The issue with these is the plastic forms around the screw and it no longer expands
1. Pic shows what it looks like with screw in with and without fix
2. Cut 2 very thin pieces of metal, even a strip from a Coke can would work, what I used was just a bit thicker
3. Glue it in with epoxy, and use a flat head to clamp it. Put some paper around the flathead so if glue gets on it you can still pull it out
4. Done
