Flashing airbag light
Pistnbroke (08-27-2022)
Dr. D (07-06-2022)
Pistnbroke (07-06-2022)
Here you are code 26...All sounds a bit OTT to me ..just check out the passenger seat belt switch and wiring.
Jaguar Xk8 - 26 Airbag Code - 26 SRS Light For Jaguar Xk8 - AirbagCode.com
Dr. D (07-11-2022)
Hi pistnbroke I think the 2005s have a diffrent set up ie there is no seat postion sensor on the bottom rail there are 3 occupancy sensors 1 on the post between windscreen & door my problem . 1 over head were the internal lights are . 1 Just behind the passenger seat After replacing the weight sensor in the passenger seat without cure .Went to see a independent Jag man worked it out in 30 mins Andrew Lindsay Northern Ireland
newbiegurl
09-19-2012 08:33 AM
