flat battery
Old 12-26-2008 | 06:02 AM
richard134's Avatar
Default flat battery
flat battery and dont have the correct key to open boot by xk8 badge at back. help!
Old 12-26-2008 | 07:17 AM
Fjk's Avatar
Fjk
Default RE: flat battery
The engine compartment fuse block has a stud with a rubber cover supplying 12v to the fuses. Connect a battery charger to the stud and a good ground. That should give you enough to gain access to the battery.
Old 12-26-2008 | 07:41 AM
richard134's Avatar
thanks Fred, have located the stud, i take it i attach the live to this but what do you mean by a good ground/ do i attach other lead to body wing or what? Also when both connected can i charge battery fully here or do i need access to battery?
Old 12-26-2008 | 08:36 AM
Fjk's Avatar
Fjk
+12v ( or as you said "live") to the stud.
A good ground is the heat shield just below , between engine and chassis.
You can charge the battery this way, or just use the power to open the trunk (boot).
Old 12-26-2008 | 11:27 AM
richard134's Avatar
Many thanks Fred all charged up and running, had to reset windows but no prob. Take for run tomorrow to give good charge. Not been used for 5 weeks is that enough to flatten battery?
Dagny
06-11-2024 01:06 PM
shootingbrake
09-23-2015 10:54 AM
Guy-Pierre Boucher
09-16-2015 05:55 PM
Dickie_L_J_O
09-13-2015 07:44 AM
DEklof
09-08-2015 05:28 PM
Quick Reply: flat battery
