Flat battery in key?
Is there a battery in the ignition key? I tried the spare key a couple of weeks ago and, although all the lights came on, the engine wouldn't fire. Then last night I went to fill up with petrol and the car wouldn't start with the 'master' key. I waited for a few seconds, tried again and it worked.
Not very reassuring! Anyone have any ideas/similar experience?
There's a battery in the fob for the remote door opening/alarm etc but not for the actual key itself.
The key does have a transponder chip which is programmed to the ignition. Has the spare key ever started the car? Is it the original? If not it may not be programmed to the car.
If it needs to be programmed a dealer can do it, but will charge, possibly a lot. Some key cutting places have a programming machine and are usually cheaper, in fact I found one who progarmmed a key for me for nothing.
Not sure why the master key hesitated.
I have the 3 keys for mine. 1 didn't work and did as you describe - lights on, dash power, etc, but no turnover. I took them to the dealer to reprogram. Like an idiot, I left the dealer (which was 1000) miles from my house without actually trying all of the keys. When I got home a different key didn't work. The one that originally didn't work now worked, and the one I had been using before the programming didn't work.
Long story longer, I think it may have something to do with the chip in your key and could need to be reprogrammed. If you start the car with a key that works, turn it off, and insert the key that doesn't it WILL start - provided its done immediately after the car was running. If you wait a few minutes, then the unprogrammed key will only key lights, etc.
Frog (04-27-2011)
All keys have to be present to program any one key. They aren't actually programming the key, they are programming the car. The codes on the RFID chips in the keys cannot be changed. When they program the car, they wipe out any codes that are already programmed in and then program in all of the keys that are present. If you left a key at home, then it won't start the car. You need to take all of the keys back to the dealer and have them do it over again. I'm surprised the dealer didn't tell you that.
I thought they could be changed. I took my original working key, along with a non working, newly acquired, spare to a high street key cutter and he just stuck it in a machine and programmed it in about 10 seconds. He didn't go anywhere near the car and the key now works fine, so I assume that somehow the transponders can be re-programmed.
Yes, the keys can be cloned. The idea of car responding to different transponders in keys can have to do with different drivers. One key will activate all the memory settings in one position and another key will activate all the memory settings in another position, etc. Remotes can be the same way.
abraxus (04-26-2011)
Thank you so much for the tip. It was always a bit disconcerting to know that I only had one key.
Received 6,326 Likes
kabs3012
09-12-2015 10:40 AM
